Imagineer53
Apr 25, 2016Follower
C3700 Ethernet Port Fail
Using successfully on Comcast, both WiFi and Ethernet Port1.
I have a Magic Jack connected to Port-1.
Tried connecting another Ethernet Device, my Laptop PC, to Port-2. Doesn't work.
All LED's OK.
Swapped devices on Port-1 and Port-2. The problem stays with Port-2.
Now the Laptop works, but the Magic Jack doesn't. LEDs on Magic Jack are OFF.
I swap them back, and situation is as before.
This suggests to me that Port-2 is bad or, somehow, disabled.
Logged into http://RouterLogin.net.
Everything looks OK to me, but I'm no expert.
I see IP Addresses listed as being attached to both Port-1 and Port-2.
One is my Laptop and the other is what I presume to be the Magic Jack (listed as a ReadySHARE (Internal Server).
This suggests to me that the C3700 knows that something is attached.
I looked at the pins on the RJ-45 Jack. None look bent out of shape.
Any ideas?
Is Port-2 Damaged?
Is there a configuration that I should check?
Does NETGEAR offer a 'SWAP' Replacement, through RMA process?
Thanx -
- Ellery
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Imagineer53
I would check the router mode setting make sure its enables go to Advanced-Administration-Router Mode.
DarrenM
