gdeglin
Oct 17, 2015Aspirant
C3700 ipv4 speed 3x slower than ipv6 speed on comcast. Turning off WMM doesn't help.
I recently upgraded to a 150Mbps connection with Comcast. After the upgrade, I see that my download speed is 50Mbps on ipv4, but 150Mbps on ipv6. Searching online, I see that some user...
gdeglin
I accidentally uploaded the wrong second screenshot. Here is the right one...
- vkdeltaOct 19, 2015NETGEAR Employee Retired
Hi, your screenshots show pretty close speeds.
Do you have another screenshot to show the difference?
- gdeglinOct 19, 2015Aspirant
Please look again, you'll see that the first screenshot shows the following
ipv4: 52.32Mbps
ipv6: 139.04Mbps
These results have been very consistent across multiple speed test sites and over several days.
Thanks.
for some reason those screenshots are showing. can you please post again?
Can you please PM me your MAC address and the location as well and the speedtest server you are trying?
also, what kind of laptop/NIC are you using?
what FW are you running and I assuming ISP is comcast.
this is kind of behaviour is very strange.
can you please try other port on the device as well?
