franco910's avatar
franco910
C3700 N600 Speed issue
Spectrum upgraded our area for 200 mbps.  However I checked the speed with an ethernet cable and it was only 100 (my pc has gigabit ethernet).  I contacted spectrum and they said their info says my equipment is only good to 100.  However if you look at the netgear specs it 300,  What gives?
  • I got impatient waiting on an answer so I went ahead and bought the nighthawk router modem combo.  So far so good.  Getting 1 Gbps LAN and 300 mbps Wifi.  Crazy fast. Not sure I believe it.  I didn't get a chance to try your solution but thanks for replying.  Maybe it can help others.
  • FURRYe38's avatar
    Power OFF the modem for 1 minute. Then back on. Reboot your PC while the modem reboots to ready. Check speeds.
    • franco910's avatar
      franco910
      • FURRYe38's avatar
        Thought you already had this modem router combo?
        Mark your post as solved so others will know.
        Ok, Enjoy. :smileywink:
