Homyakchik
May 09, 2016Aspirant
C3700 Want to totally disable Readyshare
Howdy all Recently purchased the C3700 to replace the rental I'd been paying Comcast for. After some initial hiccups (all at Comcast's end), it's up and running and seems to be doing nicely. Litt...
- May 09, 2016
How about going to ADVANCED > USB Storage > Advanced Settings and unchecking all of the checkboxes?
You can also go to ADVANCED > Advanced Setup > USB Settings and disable the USB port.
TheEther
May 09, 2016Guru
- HomyakchikMay 09, 2016Aspirant
Argh. You are the genius, I am the moron. I hit that USB Settings thing a dozen times, and managed to miss the Advanced Settings setting every single time. Yeesh.
Thanks, and marked as Solution.
Davey
