Supsir
Jul 21, 2016Aspirant
C3700 Wireless Gateway Radio Crashes
I've got a C3700-100NAS hooked up to my Mac via ethernet. This is the second time that the wireless disabled itself (the first time it seemed to randomly turn back on after lots of coaxing, and I don'...
Supsir
Additional info as I go along:
I've tried using the router login.net via Chrome and now Firefox. Still no luck.
Its curious that in the basic wireless settings I can only attempt to tinker with the 2.4GHz b/g/n settings, I don't see anything for the 5GHz settings. Is that usual in the basic settings?
Supsir
Okay, nearly 12 hours later...
Before I left for work, I turned off the router, but someone else turned it on once I came back just now. I decided to unplug from the power port and plug back in, and that seemed to work. I don't know if it would have been the same solution if I had just toggled the power button off and on. But hey.... there it is.
