x9's avatar
x9
Tutor
Jul 18, 2022
C3700v2 - firmware on admin screen is later than the latest version offered by Netgear?
I've been having constant issues with this device for over two months now. The device will encounter connection issues at odd times and usually reboot itself 2 - 3 times a day. It seemed to happen ever since I brought a couple brand new Pixel 6's on the network but difficult for me to confirm if that's related. Today I was experiencing issues so I logged in to do a manual reboot and on the admin screen I see the firmware version is "V1.01.28". When I check the latest firmware available for this device https://www.netgear.com/support/product/WNDR3700v2 it says 1.0.1.14. Am I reading this incorrectly or did my ISP put some bogus firmware on my modem?
  • x9's avatar
    x9
    Oct 31, 2022
    The service provider had to make three trips out to my residence but they eventually replaced the entire line and the connection has been consistent. Appears it had nothing to do with the firmware.
    If anyone encounters this in the future please be sure the technician inspects the line inside your house, outside to the pole, and also across the road if your line warrants that. The first tech replaced the line from our house to the pole and declared success. We had signal issues 30 minutes after he left. The second tech found signal issues and shorts with the line from the house entry point to the modem so he re-did that and declared success, and then we had signal issues 30 minutes after he left. The third tech found signal issues in the cable leading from the bup pole across the street to the main pole, so he replaced that and the splitter box where all the other neighbors tap in. I'm not sure how you ensure the tech does this because they'll get offended if you scrutinize their work, but I just wanted to stress the importance of a comprehensive analysis of the entire line.
    • x9's avatar
      x9
      Tutor
      Sorry that was a typo and I see now I was visiting the wrong page. I do have the C3700v2 and after seeing this page   I see that the ISP (Spectrum) has provided the latest firmware. Here is the info from the Cable Connection screen:
      Frequency start Value
      This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
      Starting Frequency
      <tabindex=-1>Startup Procedure</tabindex=-1>
      ProcedureStatusComment
      Acquire Downstream Channel405000000 HzLocked
      Connectivity StateOKOperational
      Boot StateOKOperational
      Configuration FileOK
      SecurityEnableBPI+
      IP Provisioning ModeOverride MDDIPv6 only
      <tabindex=-1>Downstream Bonded Channels</tabindex=-1>
      ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
      1LockedQAM25623405000000 Hz-0.1 dBmV41.4 dB23322708
      2LockedQAM25624411000000 Hz-0.2 dBmV40.8 dB21652468
      3LockedQAM25627429000000 Hz-0.1 dBmV41.4 dB19162187
      4LockedQAM25628435000000 Hz-0.2 dBmV41.3 dB18792770
      5LockedQAM25630441000000 Hz-0.3 dBmV40.9 dB18642450
      6LockedQAM25631447000000 Hz-0.3 dBmV41.3 dB19412659
      7LockedQAM25632453000000 Hz-0.2 dBmV41.3 dB19922610
      8LockedQAM25633459000000 Hz-0.2 dBmV41.4 dB17832377
      <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
      ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
      1LockedATDMA895120 Ksym/sec17600000 Hz46.3 dBmV
      2LockedATDMA905120 Ksym/sec24000000 Hz47.3 dBmV
      3LockedATDMA925120 Ksym/sec36800000 Hz49.5 dBmV
      4LockedATDMA915120 Ksym/sec30400000 Hz48.0 dBmV
      Current System Time: Tue Jul 19 09:16:00 2022
    • x9's avatar
      x9
      Tutor
      I'm not sure these event logs encompass the time frame I experienced the outage but next time I have an issue I'll be sure to note the time.
      TimePriorityDescription
      2022-07-19, 08:49:43.0Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 05:21:45.0Warning (5)MDD message timeout;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 05:21:00.0Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 05:21:00.0Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 05:20:50.0Notice (6)Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
      2022-07-19, 05:20:43.0Critical (3)No Ranging Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.0;CM-VER=3.0;
      2022-07-19, 05:20:28.0Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 04:11:39.0Warning (5)MDD message timeout;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 04:10:50.0Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 04:10:50.0Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 04:10:37.0Notice (6)Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
      2022-07-19, 04:10:31.0Critical (3)No Ranging Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.0;CM-VER=3.0;
      2022-07-19, 04:10:17.0Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 04:10:17.0Critical (3)Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 04:10:17.0Critical (3)16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 02:32:11.0Warning (5)MDD message timeout;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 02:32:10.0Warning (5)MDD message timeout;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 02:32:10.0Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 02:31:23.0Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 02:31:23.0Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 02:31:12.0Notice (6)Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
      2022-07-19, 02:31:05.0Critical (3)No Ranging Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.0;CM-VER=3.0;
      2022-07-19, 02:30:50.0Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-19, 02:16:28.0Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-18, 12:51:09.0Warning (5)MDD message timeout;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-18, 12:50:36.0Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-18, 12:50:36.0Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-18, 12:45:29.0Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-18, 12:43:12.0Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-18, 12:41:34.0Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      2022-07-18, 12:41:12.0Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0;
      Time Not EstablishedNotice (6)Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
      • plemans's avatar
        You have errors in the line and the logs indicating line issues.
        Start with removing any amplifiers, signal attenuators, or splitters from the coax.
        From there check the line for kinks, damage, moisture in the line.
        Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
        If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
