petewatterschat's avatar
Mar 27, 2017
C6300 and NAT Loop Back
NAT Loop Back - a mobil device can use the WAN address for both local LAN access and Remote Access
Does the C6300 support this and is there a spec sheet that states this.
I have not purchased yet and this is a requirement
  • Retired_Member's avatar
    Retired_Member
    Even with the latest firmware on the c6300 from TWC / Spectrum, there is no option for NAT loopback. You are better off getting a dedicated cable modem, and separate wifi router for this purpose.  If you are going higher than 100mpbs service, get a higher end newer version of this unit.  Other than that, i can the c6300 is a stable unit which has provided solid performance, no disconnects, very few reboots, and works with most wifi devices.  Good luck with the other brands, i just went through 4 high end routers and the highest rated arris modem, I found too many issues, and I can work around my NAT loopback needs.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    C6300 FW V2.01.14 supports NAT Loopback there just isn't an option for it in the UI.
    DarrenM
