SteveCole
Dec 18, 2015Aspirant
C6300 Block Sites not working
Does this feature work? I've added several keywords, including full host name, but the router won't block access to it. Here's the settings...
The feature will only work on http URLs. It won't work with https URLs.
- SteveColeAspirant
Is there a firmware update planned soon to fix this?
https is encrypted, so it's fundamentally impossible to fix this. I suggest you try parental controls, either using Netgear's or OpenDNS directly.
- SteveColeAspirant
Jeez! Why didn't they include a simple IP address/address range to block? And Parental Controls doesn't work. The built in http app only opens a pop-up where you can download apps. If you download, install the PC app and use it, when you click the Parental Controls button, it can't find the router. It just sits there on a "Checking router firmware" page.
