erhnam12
Jul 05, 2017Tutor
C6300 Cannot resolve host - Cannot access internet outside of bridge mode
My C6300 is just 4-5 months old and had been working great so far. I was on vacation over the long weekend and had the power to it turned off. I come back home and turn it on to no internet. Sp...
vkdelta
Jul 06, 2017NETGEAR Employee Retired
thank you for posting this. We are looking for customer such as you who are having problems specifically with "spectrum".
1. What FW do you have on the device?
2. what happens when you take the device in NAT/Gateway mode?
3. Does the WIFI come if you FACTORY RESET the device and NOT connect it to spectrum and WIFI suddenly goes when you connect it to the spectrum network?
Please URGENTLY PM with your info.
erhnam12
Jul 06, 2017Tutor
1. V2.01.18
2. If that is the equivalent of switching router mode to 'No' under advanced settings then I was able to access the internet with no issues via ethernet cable hooked up to my laptop.
3. I factory reset it many times and still was unable to access internet outside of the above parameters.
Update: I somehow restored my access to normal. Although I don't know how. I pressed the two buttons on the front of the router/modem (one for WifI, one for WPS) so that their green lights turned off. I waited a minute or two and then pressed them again until the lights came back on. I was able to access the internet after going through those steps. Everything went back to working just fine. Wifi included. I don't know why that fixed it.
- vkdeltaJul 06, 2017NETGEAR Employee Retired
Ok. thats good.
Please let us know if the problems comes again.
- erhnam12Jul 08, 2017Tutor
So the problem came back.
I had some issues with my phone dropping Wifi connectivity every so often after getting it back running. So I tried a reboot of the modem/router and now it is back to not working.
I can only access the internet when I goto settings and turn router mode off.
I can't seem to replicate the series of events that led me to get it working the first time. Might need more trial and error but this is very frustrating.
- vkdeltaJul 08, 2017NETGEAR Employee Retired
can you please post some screenshots of the GUI and pictures of the LEDs?
