perkerk
Aug 22, 2015Aspirant
C6300 LAN Setup Address Reservation bug
Netgear Genie on my C6300 firmware V1.02.19 has a bug in the address reservation logic. The initial Lan Setup screen shows the reserved devices. In some instance when you press Add (to reserve a ...
perkerk
Well, stymied again. Was able to get to the 2nd screen a few times, but no more, whether a device is selected on the initial page or not.
JustinDay
Aug 31, 2015Initiate
I get the same error after adding 4 reservations and can't get around this even if I jump on one foot while rubbing my stomach and patting my head... I am supprised there is no firmware update that addresses this yet. Currently running Firmware V1.02.21 and don't see any options to even download a firmware version from the support page.
I am seriously looking at selling this device and buying a non Netgear cable modem/router combo.
- SeaDudeSep 12, 2015Aspirant
Same problem here: Although i'm unable to reserve a single IP.
I am unable to reserve an IP address using "LAN Setup" then the "Add" button under "Address Reservation". When I click "Add", I get a progress bar at the top that says "Updating Settings", then when that finishes I get the "Chrome Sad Face" with an error that says "The server closed the connection without sending any data" and I'm unable to do anything else.
What is causing this?
I'm using Chrome and C6300 firmeware v1.02.21 if that helps.
- DarrenMSep 15, 2015Sr. NETGEAR Moderator
Hello everyone
SeaDude figured the issue out and posted it in another thread.
DarrenM
- SeaDudeSep 15, 2015Aspirant
Playing with things a bit more....
Im running a repeater bridge off of my C6300. I had to unplug it while I reserved IP's as well. Not sure if it matters to others, but may be of use.
Cheers.
