Pakled
Jan 31, 2016Follower
C6300 NAT Settings
Hello All,
My son is trying to use his XBOX App on his WIndows 10 Laptop and when he tries to join a party and chat with his brothers he gets an error saying his network setting won't allow this. My thought was I probably need to open the NAT settings. However, when I went to WAN setup there isn't any NAT filtering option to change. I think it's supposed to be by the "Disable SIP ALG" setting but I see nothing there. Any advice/help would be greatly appreciated.
Pakled
1 Reply
The NAT setting is usually in WAN setup, but it's not mentioned in the manual, so it's possible that the setting is not available on the C6300. :smileysad:
Here are some options:
- Try enabling UPnP(ADVANCED > Advanced Setup > UPnP). The XBOX App may use it to open the ports automatically.
- Try using port forwarding instead of UPnP.
- Put your son's laptop in the DMZ (kinda dangerous).
- Buy a router capable of opening NAT and disable router mode on the C6300 (ADVANCED > Administration > Router Mode > No)
- Replace the C6300 with a better modem/router
Options 1 and 2 are the easiest to attempt, but they won't guarantee success. It depends on the missing NAT filtering option.
