schatzi's avatar
schatzi
Follower
Jul 02, 2020
C6300-no internet connection
I had a Netgear router/modem that has worked for the past year and a half. Yesterday, it no longer showed up in my network options. Contacted my internet provider and they said it was the router/modem. Bought a new router/modem today and cannot get it to connect to the internet. Any ideas?
  • olympos1625's avatar
    olympos1625
    NETGEAR Employee Retired
    Hi schatzi,
    Good day!
    Welcome to NETGEAR Community!
    We would need the following information, so I can offer you additional recommendations:
    1. What is the model of the new modem that you purchased?
    2. Did you contact your Internet service provider already to provision the new modem?
    I look forward to your response.
    Oliver
    Community Team
  • plemans's avatar
    Did you buy the C6300?
    If you have any splitters, amplifiers, or attenuators in line, remove them.
    I'd also move the modem/router to right where the coax enters the home to ensure it isn't a wiring issue internal to the home.
    Are you abel to access it via a hardwired (ethernet) connection?
    If so, get a screen snip of the cable connections page and logs.
