comeauxn712
Aug 25, 2017Aspirant
C6300 Router Mode Can't Be Enabled
I am having a very strange set of issues with my device. I recently bought the C6300 with the hope of simplifying my network and having a quality fast Modem Router combo. I was initially able to log ...
vkdelta
Aug 25, 2017NETGEAR Employee Retired
who is your ISP? is it spectrum?
- comeauxn712Aug 25, 2017Aspirant
Yes, it was Brighthouse and then my account got switched to Spectrum once they were purchased.
- DarrenMAug 28, 2017Sr. NETGEAR Moderator
Hello comeauxn712
There was a issue with spectrum billing system disabling the router mode on modems contact them and have them check all of the coding for your modem to make sure it was not disabled on there side.
DarrenM
- comeauxn712Aug 31, 2017Aspirant
This does seem to be the issue, unfortunately none of the 5 tech support people I have talked to have been able to fix this (the last guy spent an hour on it)
