karanv
Sep 02, 2015Follower
c700 - Bridge mode
I can't get to me C7000 once I put it in bridge mode by going to the default ip addr out of the box (which I didn't change) I tried both connecting a wrkstn directly to the C7000 and using a client on the network. I have also tried routerlogin.net/com. C7000 as a router (not in bridge mode)I have no problem using the 192.168.0.1 address and loging into the device.
Q: Is there a way to manage the C7000 in bridge mode. I haven't been able to. The Genie app lets me see Internet, Wifi, Network map, but router settings errors out with "no supported router" error.
Thanks for your help
-karan
1 Reply
- rpoffenVirtuoso
Usually when a modem is in bridge mode, there are no settings, all it is acting as is a dumb interface from the broadband side to the ethernet side. In order to get it back to normal mode is to do a hard reset on it.
