Bobby91
Mar 24, 2017Aspirant
C7000 poor wifi, caused by traffic?
So I have a C7000 modem/router combo though Comcast. I'm paying for speeds up to 200mbs. Right now I get 50 IF I'm lucky. Comcast says that it is caused by high traffic and that i should go back to th...
michaelkenward
Mar 25, 2017Guru - Experienced User
200 Mbps over wifi is a big ask.
Spend some time on Google and you will find that there are limits to wifi speeds.
What is the actual real-life speed of wireless networks ? :: SG FAQ
Everyone says to just plug it in through LAN to get higher speeds ...
They are right.
You may get better speeds if you use powerline adapters to create a wired network.
