JessAOII's avatar
JessAOII
C7000 won't connect to NetGear Genie to allow Parental Controls
I can connect through the web to our modem/router but will not connect to Netgear Genie program on my laptop or on my android phone.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello JessAoil
    Do you get any type of error when trying to access genie?
    DarrenM
  • It just tells me that my password is wrong but I use the exact same password when I access it through it IP address.
    • DarrenM's avatar
      DarrenM
      Hello JessAoll
      Try to change the password on the routers login or even go back to default one password to see if that will let you in.
      DarrenM
  • I have the same issue except mine tells me that the network is busy and to try again later. I jave rebooted everything on my end a few times but it doesn't help.
