Arahn's avatar
Arahn
Tutor
Jan 11, 2022
C7000v2 Amber Light Issue
Starting a new topic because I can’t find any issue like mine:
My modem/router suddenly stopped supplying internet in the middle of the day. I tried multiple factory resets, power-cycling, the works but nothing changes. The Upstream, Downstream, Online, 2.4 GHz, and 5 GHz are solid amber while every other light is solid green.
Has anyone encountered this before or know what the problem is?
  • sounds like a hardware failure. What I'd try?
    Disconnect if from the coax and hold reset for up to 30 seconds while powered on.
    See if that resets it.
    If it doesn't, it might be toast.
    Is it still within warranty?
  • plemans's avatar
    are you able to log into the router and get a screen snip of the cable connections page and event logs?
    • Arahn's avatar
      Arahn
      Tutor
      No, the wifi doesn’t appear and if I try search for the network using the information all my devices say they can’t find it, so I can’t log in. The nighthawk app can’t find or connect to it either.
      • plemans's avatar
        If you hardwire a pc/laptop into it, can you access it at 192.168.100.1
