xx2pro4uxx21's avatar
xx2pro4uxx21
C7000v2 connects but no internet
I just got wifi today but I'm running into a problem where my PC connects to the wifi and it says that I have internet access but I'm still not able to connect to the internet. From what I've found online, the wan light is on but isn't blinking. So I've turned everything off and followed the process with that with no change. I downloaded the Ethernet driver for my PC and I was able to get the Ethernet to connect now but same problem with not having any internet. All of the lights are green and a couple of them blink a little bit but not the wan light.
    • plemans's avatar
      You missed out on some channels. Scroll down a bit.
      But from the initial, you're not getting all your channels locked.
      Try removing any splitters or signal attenuators from your line.
      Check for kinks, damage, loose/old/bad/corroded coax cables and remove them if you do
