Gabbychief
Apr 06, 2020Aspirant
C700v2- Naming Devices on Network
My device is not supported by the Orbi app, do I need that to change the device names on my network? I was using the Genie app and I had all my devices named. I can turn them on and off by name, which...
- Apr 06, 2020
Try inputting 192.168.0.1 into a web browser on your PC.
Apr 06, 2020Guru - Experienced User
Use a wired or wireless PC or laptop and connect to the modems web page using a web browser to make changes to device naming there.
The Orbi app is only supported for Orbi MESH systems.
Ask NG to enable support for the modem on there NH app.
- GabbychiefApr 06, 2020Aspirant
Thank you for your response. I do not know what is meant by loggin into the modem webpage. I know how to go online using my PC and log into my account. I do not see the devices that are on the network. These instructions are to change the names for devices that are logged into the network correct, and not the name of my hub?
- FURRYe38Apr 06, 2020Guru - Experienced User
- GabbychiefApr 06, 2020AspirantThank you so much, this worked!
