2ndstringroadie
Aug 23, 2017Follower
C7100v Netgear Genie Remote connection
I just bought a C7100v modem/AC1900 router. I can get the Netgear Genie app to connect locally, but having issues with the remote connection. Turned on the remote connection on the web portal. Tried redownloading the app, and reboots....
Thanks for your help
- DarrenMSr. NETGEAR Moderator
You may want to check page 105
http://www.downloads.netgear.com/files/GDC/C7100V/C7100V_UM_EN.pdf
DarrenM
- vkdeltaNETGEAR Employee Retired
C7100V (or any Cable Modem or Cable modem router) Does NOT support Remote Genie.
remote management is DIFFERENT from Remote Genie.
remote management is HTTP web GUI
Remote Genie is via Genie app
