bloodyknuckles's avatar
Apr 29, 2020
C7500 no wifi or ethernet
Came home today to find my modem/router not functioning properly. It's getting internet signal but none of my devices can get wifi or hook up using ethernet. I also can't get to the page to access the router using 192.168.0.1 or routerlogin. I can power cycle it but when I reset it for 7 seconds it does nothing. No blue lights are on and only the first 4 solid white lights are on. Also the #2 white light is solid with nothing connected into the #2 port.
  • plemans's avatar
    Try unplugging the coax from the modem. When powered on push and hold reset for 7-15 seconds. The lights will change when held long enough.
    Then connect the coax and reboot it.
    try accessing it 192.168.100.1
    Can your isp see/ping it?
    • bloodyknuckles's avatar
      bloodyknuckles
      When I followed these steps and hit reset, the top 4 lights only flash for a few seconds then stay white. So, after following all these steps it still didnt work and couldnt access the router. My ISP can see the modem.
      • plemans's avatar
        solid white on the top 4 tend to indicate good things. (see the manual for specifics)
        If you hardwire into the c7500, can you access it from 192.168.100.1?
        Have you tried a different laptop/pc?
        Did the wifi on/off button get pushed somehow? push and hold it for 2 seconds.
        As well as there's a led button on it with 3 modes.
        https://www.netgear.com/support/product/C7500
