braddman's avatar
Jul 25, 2021
C7800 - Cannot connect to 2.4Ghz anymore.
Firmware Version
V6.01.07
So this is super annoying. I cannot connect to the 2.4ghz wifi anymore with my phone. 5ghz works fine. A lot of devices are still connected to 2.4 but I just cannot connect. Tried rebooting, etc. No effect. The error on the phone is COULDN'T AUTHENTICATE CONNECTION. Same with my echo shows. They all say INCORRECT PASSWORD. And of course there's no more tech support for this $400 cable modem.
Computer says CAN'T CONNECT TO THIS NETWORK. Rebooted the modem over and over.
  • plemans's avatar
    1. you say some devices are connected to the 2.4gh? how many? which ones connect? which ones dont?
    2. did you try changing the password? remove any special characters or spaces from the ssid/password?
    3. when did it start? Was anything changed when it started?
    • braddman's avatar
      braddman
      Star
      Looks like the firmware was updated by Comcast. Recently started in the last couple days. Yeah changing the password has no effect, it does the same thing.
      • plemans's avatar
        have you tried a simple factory reset and reinstall?
        Push and hold reset for 7-15 seconds while its powered on
