blueeagle's avatar
blueeagle
c7800 no bridge option under Advanced/ Administration.
 I need to enable bridge mode on my c7800 because I am installing a ERRO whole home wifi. However, when I go to the router login, under advanced-administrative there is no bridge mode option. Where can I setup the birdge mode? Any help is appreicated.
  • Ok, look for NAT mode. I forgot this model gateway named the mode differently. NAT mode should set to No.
    blueeagle wrote:
    Unfortunately their is not Router mode under Advanced or any other menu item. I am on latest Firmware VersionV6.01.07
    • FURRYe38's avatar
  • Unfortunately their is not Router mode under Advanced or any other menu item. I am on latest Firmware VersionV6.01.07
  • FURRYe38's avatar
    https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
    Look for Router mode menu feature under Advanced Tab/Advanced Settings?
