Troach6
Apr 16, 2021Follower
C7800 power supply part number
My Power Supply Was Lost During A Move And I need To Purchase Another. Can Someone Get The Part Number For Me Please
michaelkenward
Apr 17, 2021Guru - Experienced User
Netgear does not sell replacement power adapters. Any generic adapter will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions.
If you search in the usual places, you may find some that say they are compatible with your Netgear device, or a model that has the same power specifications.
