charleyrich
Mar 29, 2025Aspirant
C7800 upgrade?
I have a c7800 midem/router that is aging. My home is 2,000 sqft, my internet provider is Xfinity and I have their 500gb plan. I have about 20 devices connected to my network.
What is a reasonable combo upgrade that will cover my requirements but not break the bank.
charleyrich wrote:
What is a reasonable combo upgrade that will cover my requirements but not break the bank.What is it about the C7800 that causes you grief? 20 devices is nothing for a device like that.
You want another modem/router? Experienced users prefer separate devices.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
Cable Modem Routers: Modem Router Combo | NETGEAR
andThen check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
Disclaimer: Just another user with time on their hands.
- charleyrichAspirantThe problem: I need to reboot the device once a week as it begins to slow down dramatically. My normal speed of 500+Mbs drops and stays at ~100 Mbs. A lot of device start failing to connect. Also, Xfinity stopped supporting the device. I suspect I am no longer getting updates.
I would like a recommend of a combo that doesn't have these issues and supports Wi-Fi 6.
Thanks- plemansGuru - Experienced User
The C7800 was the best modem/router combo device before the CAX line came out. Its a pretty rock solid device and docsis 3.1. It should handle your needs easily. the slow downs are probably line related.
do you have a screensnip of the cable connections page (show your upstream/downstream values) and the event logs? that helps check the line back to the ISP.
