herofabled's avatar
herofabled
Follower
Jun 30, 2021
c7800 wifi radios not working
i had a power outage and my wifi will not turn back on. in advanced wireless settings they (wifi radios) are enabled but the LED's are not lighting up and i have no wifi networks. Pressing the Wifi button on the device is useless.
I've tried reseting the router and nothing. What should i try?
It also doesnt save any changes when i click apply and takes REALLY long to load any page (on router setting) except actual internet on my hardwire connection which is running flawlessly.
  • FURRYe38's avatar
    Try pressing the top case wifi button for 5 seconds, LEDs should turn ON.
    Try a factory reset by pressing the reset button for 10 seconds then release. Wifi LEDs should turn ON after this....
    Try a different power supply with same power specs.
    If not, contact NG support for addition help and information.
  • This also happened to me last night! THE EXACT SAME ISSUE Something fishy is going on because I've seen another user with this same problem. Maybe this is security flaw and we all got hit. What firmware are you running by chance? any changes is ISP? Happen to be on Cox?
    • FURRYe38's avatar
      If the wifi radios are not working,even after a factory reset. You can just disablle them in the UI. Then connect up any other wifi system to the C7800 and continue to use the C7800 as your modem and router as a alternative suggestion. There are better wifi systems out there that are way better than the wifi thats on the C7800.
      • fmlipton's avatar
        fmlipton
        Same issue, no wifi radio.  Happened about a month out of warranty and I can get no help from Netgear.  I'm ready to through the piece of junk in the trash.  Last time I purchase anything from Netgear seeing how they don't stand by their products at all.  My wifi radios stopped working after I resetted the modem.  Now no radios, doesn't show 2.4 and 5 radios in the setup anymore, it only shows one.  And it takes forever to refresh the setup afer changing anything.  Don't waste your money.
