iceguy
Oct 07, 2024Aspirant
cable connection test doesn't work
I've been having issues with reaching my Xfinity 2gb/s download speed and noticed that the cable connection status is 'poor' through the admin tool. However, I cannot run the cable diagnostic test as it shows a progress bar, but no results present on the web browser after assumed completion. Xfinity support has been out here twice and verified everything up to the modem/router is correct. There was a month period after upgrading from 1gb/s to 2gb/s that this worked until something appeared to change for the past 3 months, so any idea how to proceed?
So you have a CBR750?
If so, what FW version is loaded on it?
Try accessing the cable connections and event logs on the CBR using a different browser.
What browser are you using? Try MS Edge or Firefox.
If you can't gain access here, try a factory reset and setup from scratch. I'd disconnect the ISP cable coax line during this process as well. See if you can get to the home screen with out anything connected and try the cable connection or event logs pages. If you can gain access, re-connect the ISP cable coax line.
- iceguyAspirant
Using the latest firmware, V4.6.14.4_2.3.12. I've tried accessing the cable diagnostic both from chrome and edge without success. should I rollback firmware versions?
How about Firefox?
Even after a factory reset with the ISP cable disconnected, won't access the web pages?
