MasterMaker
Jan 12, 2016Aspirant
Cable modem CG3000 doesn't show all Network connectins
Hi All, I have a cable modem with an add on newtork switch, the network map wont show IP's on the switch ?
MasterMaker
Just depends on the printer it may be located on a sticker or if you have some type of networked interface to log into for the printer it would be in the network settings.
DarrenM
- DarrenMSr. NETGEAR Moderator
Hello MasterMaker
What type of switch are you using?
DarrenM
- MasterMakerAspirant
Hi Darren, it is a Netgear 5 port GS605
Chris
MasterMaker
Does the modem show the Switch at all? and have you tried to do a address reservation for one of the devices then see if it shows up?
DarrenM
