kpowe
Apr 04, 2017Aspirant
cable modem setup
Hello, I recently purchased the CM400 cable modem and had it activated with my cable company. After activating the modem, I connected the ethernet cable from the modem to my wireless router. Everything is working/connecting just fine, but I noticed the ethernet light on my modem keeps blinking orange. I was wondering if I need to do anything additional with the setup or there is a way to make it stop blinking. If anyone could help answer my question, I would greatly appreciate it. Thank you for your time!
- VE6CGXMaster
When it is running Light color signifies whether you are running at 100mbps, of 1000mbps(1Gigabit per ssecond) speed. What is your modem specs?
- kpoweAspirant
Thank you VE6CGX for your reply. How would I go about locating this information?
- DarrenMSr. NETGEAR Moderator
Hello Kpowe
Here is the user manual.
http://www.downloads.netgear.com/files/GDC/CM400/CM400_UM_17July2015.pdf
DarrenM
