landenlabs's avatar
landenlabs
Cable Modem Wifi Router with SNMP
Which cable modem Wifi Routers supports SNMP ?
Based on a previous post the SNMP is only available to ISP on the AC1900 C700.
I don't understand why the router supports SNMP but it is then blocked !!
Is there a different model which has full SNMP support ?
Also - do you have a table view which compares all of the cable model features between all of your product offerings. You have too many choices, hard to pick one.
  • plemans's avatar
    SNMP tends to be more business class products and not consumer products.
    Not sure if you'll find anything from netgear on the consumer side supporting it for modem/router.
    Why not just get a modem only device and setup your own router that supports snmp.
    • landenlabs's avatar
      landenlabs
      I use the SNMP to monitor the load on the router via my smart phone.
      My cheap TP-Link Archer C50 V5 supports it.
      Seems like a simple enough feature to allow for easy remote monitoring.
