mjt3727
Feb 02, 2017Tutor
Cable service and modem compatibility
I have interent service with Xfinity supplying up to 300 Mbps download rates. I have a Netgear CM400 modem rated at 340 Mbps. Xfinity claims that this modem is only capable of 150 Mbps. It should be ...
- Feb 07, 2017
mjt3727 wrote:Is there a technical reason why ISPs couldn't allow an 8 channel modem on a 300 Mbps subscription?
I don't think there is a technical reason; I just think the provisioning system is setup this way to prevent Comcast reps from doing this. I'm assuming 99% of people on 300Mbps tier actually want 300Mbps. This way they don't create situations where customers complain about not receiving advertised speeds.
Cox was same way; I was on Ultimate tier (150Mbps) with an 8 channel modem. At the time, 16 channel modems (or higher) didn't exist. When Ultimate was bumped to 200Mbps and then to 300Mbps, they wouldn't update my profile for higher speeds until I got a 16+ channel modem.
DarrenM
Feb 06, 2017Sr. NETGEAR Moderator
Hello mjt3727
It maybe due to the 8 downstream channels Xfinity may need more than that to provide that speed but I would check with comcast again and ask for a explanation on this.
DarrenM
