alzibiades
Sep 29, 2016Aspirant
Can’t access my WD My Book World network hard drive via my Netgear D6300 Router
Bought the new C6300 but network drive is no longer visible. I plugged it into the ethernet connection on back of modem/router but my computerWD software can not see it. I have not been able to figur...
DarrenM
Oct 04, 2016Sr. NETGEAR Moderator
Hello alzibiades
Are you able to ping the drive at all or is it showing up to the attached devices?
DarrenM
alzibiades
Oct 09, 2016Aspirant
It is showing up on the modem as connected but I can't access it from any electronic device. I have disabled my firewalls on each device thinking that was the problem but it still will not locate it. At this point I am at a loss on what to do. I have reset the settings on the modem thinking that it had some internal firewall or something and I still get the same result.
