Cax80istrash's avatar
Cax80istrash
Cannot connext to network
Recent power outage here and my cax80 will not let me connect to the network via wifi or ethernet now. I've tired a factory reset, wps buttons or wifi buttons do not light up or work. I've resorted to using my old c7000v2 and everything works fine, just not as fast as the cax80 when it worked. Cax80 I guess is destined for the trash... Anywords of wisdom?
  • michaelkenward's avatar
    michaelkenward
    What modem/gateway sits in front of the router?
    Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
    It may help to reboot the whole network in the right order.
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it to connect.
    • Turn on computers and rest of network.
    Tried pressing the wifi on/off switch?
  • FURRYe38's avatar
    After pressing the reset button for 10 seconds with the CAX80 connected to the ISP coax line, can you access the modems setup web page 192.168.1.1 at all with a wired PC and web browser?
    How long have you had the modem for?
    • Cax80istrash's avatar
      Cax80istrash
      No I can not as I just attempted to with my laptop. I've had the modem now for maybe 6 months now I would say.
      • FURRYe38's avatar
        Can you try pressing the reset button for 1 full minute then release...
        Also might try doing the 30/30/30 reset process.
        olympos1625
