serialnick
Dec 23, 2016Initiate
Cannot figure out how to factory reset C3000 router
This is a wireless n300 router with model number c3000 running on Windows 10. Somehow i've managed to mangle the admin password for router login (note: NOT the wifi password--i'm up and running with no problem but i can't make any changes to router settings). All the documentation however directs me to login to the router (!) to do anything I would normally do like change the password or do a factory reset. Some other models i notice have a handy reset button on the back, howeever this model does not. Any recommendation on how to get past this, or how to do a reset without having to login to router?
Hello serialnick
The reset button may be located on the bottom of this modem should be a small pin hole.
DarrenM
- DarrenMSr. NETGEAR Moderator
Hello serialnick
DarrenM
- serialnickInitiate
Right you are! Thanks!
