btk55343's avatar
btk55343
Follower
Feb 28, 2017
cant logon to cg3000d
Bought a used cg3000d. Connected it directly to pc but cant logon. Reset to factory default and default creds not working.
Is there a way for Netgear to format firmware so that I can sign in?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello btk55343
    Make sure you are holding the reset button down for atleast 10 seconds this should default the unit back.
    DarrenM
