ZanesRath's avatar
ZanesRath
Follower
Oct 08, 2015
Cant Portfoward Anything Netgear C6300BD AC1900 HELP!
Okay so I have followed there little guide to the T nothing has worked can someone please help. I do a port check and it does not work!
I would really appreciate if anyone could let me know if they have run into the same issue and how they fixed it if they did I have been through 3 of these just to make sure that it was not the Cable Router Modem. I did everything right.
I went to portforwarding I set it to port 80 and then set the 192.168.0.6 which is my computers default IP and for some reason it does not work.
I have checked my firewalls and everything nothing is working I have even tried it on multiple computers and still nothing! HELP!!!! Please!
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello ZanesRath
    Its a know issue with the c6300 having issues with port forwarding which will be fixed in a new Firmware update. This update is pushed out by your ISP so I am unable to give you a ETA on when that will be but I know it will be soon.
    DarrenM
