Huston1976's avatar
Huston1976
Can't update N600 (C3700 100NAS) firmware nor disable IPv6
I have a N600 WiFi cable modem Router and I cannot update its firmware. I went to advanced-Administration and there isn't an option. The firmware is way outdated but I cannot update it! How can I update it? Also, I want to disable IPv6 as I understand it will help with a Chrome/Facebook issue where my cpu goes to 100% and the feed won't load. How do I do that?
    • Huston1976's avatar
      Huston1976
      How do I go about getting them to get off their butts and update me to the latest version? They are way behind.
    • chiefdn's avatar
      chiefdn
      Guide
      And how do we get updates for ISP's that are not listed, for routers purchased from a retail outlet by the end user?  Seems highly inappropriate to sell a product that netgear wont support unless its acquired through an ISP.
    • fireman5864's avatar
      fireman5864
      Initiate
      netgear n600 c3700 firmware v. 1.01.11
      I am needing the latest version of firmware as my modem/router is very slow and losing packets. I have ran speed test when I first got it 8 months ago and I check my speeds every week the past week they dropped drasticly. I got on your site was told the firmware had to be pushed by the isp. I contacted them they got on your site and here is a copy of the reply.
      -------- Original message --------
      Date: 11/7/17 08:17 (GMT-05:00)
      To: Paul Vance <PVance@shepfire.com>
      Cc: BCI Support <support@bardstowncable.net>
      Subject: RE: netgear cable modem c3700 firmware update
      Paul,
      Unfortunately we are not able to push firmware updates to modems. After looking into the model of modem you have a bit I was able to find that you have a modem/router combo. Even though we cannot push a firmware update to the modem you should be able to log into the router page and do firmware updates from there. To access the router GUI online you will first need to open up internet explorer or whatever web browser that you use, from there you will want to type in either http://192.168.0.1 or http://routerlogin.net into the url and hit “Enter” on your keyboard. You should be presented with a login page that will ask you for a username and password. By default the username is admin and the password is password. Once logged into your router you should have the option to update your routers firmware. You may be able to find more helpful information on this page https://kb.netgear.com/24580/C3000-C3700-FAQs if you need help doing this you could always bring your modem and router in and out of courtesy we could have a look at it for you.
      Thank You,
      Johnny
      Bardstown Cable Internet Support Technician II
      I took it to them they said I needed to contact NETGEAR. So, are you going to say again it is the isp problem. And can we get this resolved.
      • jtrox's avatar
        jtrox
        Wow I can't believe there is still so little communication and or understanding between the ISP and modem manufacturers!!
        I am having Comcast installation in a couple days, I hope I don't have the same issues I had with WOW and if so I hope I can get through to someone that can get it updated. No one at WOW could.
        If not, I will have to buy a new modem and router, and I know for sure it will not be a Netgear since they are clearly not interested in fixing this disconnect between them and ISPs to improve the customers' experience.
  • Am unsure whether issue remains unresolved, as original post and comments are somewhat dated, but am sharing my experience that may be of benefit...
    Similarly have C3700 unit (originally purchased with OEM firmware V1.01.11) which has been upgraded to current V2.02.08 by Comcast xfinity ISP.
    As DarrenM has commented below, Netgear cannot directly upgrade firmware (and does not provide means for customer to upgrade firmware themselves) -- firmware version is controlled entirely by ISP.
    That said, for Comcast xfinity ISP, contacting their general technical support line is generally useless, as likely you will be connected to offshore call center whose operators have little to no technical expertise and simply regurgitating call script. Instead, directly contact Comcast Tier 2/3 Advanced Repair Dept in Denver, CO (higher level support that call centers eventually escalate to) -- their direct phone number is: 800-718-7419
    True, as has been commented on other related posts, Comcast xfinity ISP cannot manually "force" firmware updates, as firmware updates are automatically controlled by their system infrastructure. Instead, what they can do, specifically have them re-provision your cable modem, which as part of provisioning process of identifying and connecting hardware credentials to your account, it will determine your modem's firmware version and download update if necessary.
    Note, as indicated above, as of date, V2.02.08 is current firmware version, however, currently have open Netgear Support ticket (see post: https://community.netgear.com/t5/Cable-Modems-Routers/embedded-web-interface-fails-after-week-runtime/m-p/1329401#M9437) in which Netgear has identified firmware flaw in that current version as root-cause of failing embedded web interface known issue, and is supposed to release firmware fix sometime.
    • MiamiLoco's avatar
      MiamiLoco
      Thank you VERY much for the information. I did what you said and now I currently have the latest firmware V2.02.16
      • RobKat's avatar
        RobKat
        Initiate
        What did you do exactly to update it?
        I have C3700 100NAS as well and my ISP is Spectrum - firmware version is V2.02.08
        I'm worried about the Krack WPA2 and they dont seem to care about
