net6574
Dec 16, 2021Aspirant
CAX30 - Google Pixel 3XL
I have a Google Pixel 3XL. Internet was working fine with old modem and mobile data. But issues started after I got Netgear CAX30 cabel modem router and activated with my cable provider.
The issue is, some of the websites/app work, and some others do not work.
I tried to reset my phone as well. Still the same issue.
I connected to another modem router at my friends place, the internet and apps work fine 100%.
Is there any configuration that is missing?
do you have IPv6 enabled?
Are you using smart connect?
Are you connecting to the 2.4ghz or the 5ghz?
Any other device having issues?
- net6574Aspirant
Here are the answers -
do you have IPv6 enabled? : Yes IPv6 is enabled.
Are you using smart connect? : I am not using smart connect
Are you connecting to the 2.4ghz or the 5ghz? : Yes both
Any other device having issues? : Yes all other devices work
As mentioned earlier, My Google Pixel 3XL works well with other cable modems and mobile data.
If you disable AX on the router, does the pixel connect?
