Mar 15, 2023Guru - Experienced User
CAX30 Firmware Version 1.4.11.2 Released
New Features and Enhancements: 11/30/2022
• Bug Fixes
NOTE: This version of FW is most stable. Any CAX30 user having problems with FW version 2.x that was pulled and your using hasn't been downgraded, or experiencing problems with v2.x FW loaded, users are recommended to downgrade to this version 1.4x of FW.
5Ghz 1800Mpbs connection rate is supported in this version of FW.
Download Link : https://www.netgear.com/support/product/cax30.aspx#download
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button on the product page.
NOTE: This upgrade is for the ROUTER portion of the CAX only. Modem portion Firmware upgrades are pushed down by your ISP. For more information, please see our https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
To Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This article applies to:
- Brazen21Aspirant
I gave up on the CAX30 and returned the product that was 1 week old before the FW update issue. NG Tech support was little help blaiming it on internet provider. Sad I didn't even get a chance to see thei modem/routers potential.
Thanks FURRYe38 for a possible solution and good luck to all those still dealing with this.
Just got a CAX30 in this past Monday to help test for issues. Working so far on v.2 FW. Waiting for NG to re-push v2.x FW and see what happens. 😉
I'm on SparkLight ISP. Others are testing on XF as well.
- DannyS22Guide
I see that you say to do the firmware update by a PC cable direct connection. My PC and my cable/modem/router are not even close or can be. Is this mandatory? My current firmware shows version 1.4.12.2. You're showing the beta version as 1.4.11.2. Am I to do the beta or is this not the latest to be beta tested?
Thanks
Danny
Leave your current version v1.4.12.2 of FW as is. You'll be ok. I"m using same version of FW as well.
Thanks
Danny
- linareseduardoAspirant
Hello,
I would like to know if there is any updates regarding this issue.
I perfomed all the suggested instructions to fix the issue and my WiFi is still very unstable.
As you know this is not a CHEAP router and this issue is being bothering all users for a WHILE now.
Thank you,
Eddie
New FW available for the CAX30:
linareseduardo wrote:
Hello,
Thank you,
Eddie
