awdaw221fadw's avatar
awdaw221fadw
CAX30 Nighthawk packet loss on a consistent time cycle
CAX30 Nighthawk combination modem/router plugged into COAX cable from wall.  1GB/s download package.
A7000 Netgear Wifi Dongle plugged into Desktop PC.
Every minute or so, on the same time interval each time, I get 1-3 second huge lag spike.  This makes gaming impossible/enraging.
I don't understand, please help.
  • michaelkenward's avatar
    michaelkenward
    What does that mean? Is the wall socket a cable Internet connection or something else?
    Is the CAX30 modem/router in modem/router mode? Or does the socket track back to something else?
    I'm guessing that this is a  Windows PC. Which version. Is Window set to go to sleep to save energy?
    Wifi adapters
    Wifi adapter properties
    Do you have all the drivers up to date on your PC? Not just the adapter, but the USB drivers for your motherboard.
    Of course, a wired connection is the best way to connect to a network, especially if you are into gaming.
    • awdaw221fadw's avatar
      awdaw221fadw
      I mean there's no other modems or routers, just the Nighthawk CAX30.
      When I go into the interface for controlling the modem, I only see one option, and it is in "router" mode.
      It's on Windows 10.
        michaelkenward
        That raises the question as to what delvers the Internet. Those "campus" networks can track back to a router somewhere in the basement. This is not the sort of scenario that these domestic modem/routers are designed for.
        Cable modem/routers don't have a "router only" option (no WAN input). They can offer a "modem only" option, for use with a different router, but that's a red herring in this case.
        It's on Windows 10.
        Windows 10 isn't a lot different from Windows 11 on this front. Did you check the USB settings? And the drivers?
  • FURRYe38's avatar
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
