PatTestsys's avatar
PatTestsys
CAX80 - backup with 5g
Anyone have any suggestions on how to configure a backup mobile device with Nighthawk AX6000 DOCSIS 3.1 WiFi 6 Cable Modem Router (CAX80)?  My Comcast provider is unreliable, and I have no other broadband options.
  • plemans's avatar
    You mean like having a backup ISP service?
    Is that what you're asking?
    If so, that model doesn't support failover or dual wan.
    • PatTestsys's avatar
      PatTestsys
      Yes, that is exactly what I am talking about.  I think I found a solution with the new Orbi 5G system.  I can hook that to my cable modem, and it will failover to 5G when the cable modem fails.  Also supports 2 additional gigabyte lan ports, which I need.  I currently use an eero mesh with my CAX80 (the CAX80 is great wifi, but doesn't cover my third floor), so this would replace that component.  Pricey though.
      • FURRYe38's avatar
        So both CAX80 and Orbi don't support cell signal services. 5G or 5Ghz on NG products means a 5Ghz wifi signal. Not the 5G or 5th Generation cell services. Orbi as a LTE cell service product The LBR20 series.
