Seadog1975
May 19, 2021Aspirant
CAX80 not compatible with Comcast/Xfinity??
Recently purchased a Nighthawk AX8 Cable modem & router, which according to the description provided by Netgear, is compatible with Xfinity. After several months of trying to replace the Arris modem Xfinity provided with this one and spending hours on the phone with Xfinity Support (worst support ever) they are taking the position that this modem is not compaitble with Xfinity becasue it doesn't show up on their "Certified" list. (see below).
Before I duke it our with them again, I would like to know from the community if (a) this one is in fact compaitble as advertised and (b) is there some specific steps to getting to to work with Xfinity?? I am setting this up for a non-profit and they are on Comcast Business with a Fixed IP address. I pluged in all the appropriate settings for Fixed IP, Mask, DNS, etc. and it took it in just fine. However the "product support person" from Comcast said she couldnt' get it to initialize with her system which evidently has a preconfigured script it uses to ping the modem by MAC address and then push the appropriate signal to establish a WAN link. I watched as she attempted to do this and none of the settings she supposedly used made the WAN connection.
So, looking for some others who've set one of these up on Xfinity and perhaps ssme tips on getting it to synch up with them.
Thank you.
:smileyhappy:
Business Internet 200 & Below Speed TiersVendor Model Product Name
| Arris | SB6141 (Retail) | Retail SURFboard Cable Modem |
| Arris | SB6183 (Retail) | Retail SURFboard Cable Modem |
| Arris | SB6190 (Retail) | Retail SURFboard Cable Modem |
| Arris | SB8200 (Retail) | Retail SURFboard Cable Modem |
| Motorola | MB7220 (Retail) | Retail 8 X 4 Cable Modem |
| Motorola | MB7420 (Retail) | Retail 16 X 4 Cable Modem |
| Motorola | MB7621 (Retail) | Retail 24 X 8 Cable Modem |
| Motorola | MB8600 (Retail) | Retail 32 X 8 Cable Modem |
| Netgear | CM400 (Retail) | Netgear Retail Modem |
| Netgear | CM500-100NAS (Retail) | Netgear Retail Cable Modem |
| Netgear | CM600 (Retail) | Netgear Retail Cable Modem |
| Netgear | CM700 (Retail) | Netgear Retail Cable Modem |
| Netgear | CM1000 (Retail) | Netgear Retail Cable Modem |
| Netgear | CM1100 (Retail) | Netgear Retail Cable Modem |
| Netgear | CM1200 (Retail) | Netgear Retail Cable Modem |
| TP-Link | TC-7610 (Retail) | Retail Cable Modem |
| TP-Link | TC-7620 (Retail) | Retail Cable Modem |
| TP-Link | TC-7650 (Retail) | Retail Cable Modem |
| Zoom Telephonics | 5345 (Retail) | Retail Cable Modem |
| Zoom Telephonics | 5370 (Retail) | Retail Cable Modem |
It does work with xfinity. I'm on their service and it works fine. Granted I'm not the business class setup.
I'd try calling them back and seeing about a different support person.
- Seadog1975Aspirant
I'm glad to hear that - and I wasn't convinced they were right either, but I've already toalked to their da## support people 5 times now, different person each time, and they all do the same thing. When I request a higher level of support, it goes nowhere. Very frustrating. If I may ask - when you set yours up how dod you register with Comcast? Did you tell them CAX80? I don't think business should matter, but it's possible it might. I've looked on their website and don't see a difference in terms of configuration - modem gets a synch freq, puts up a DNS (or in my case pings for the proper fixed IP address, and should connect (ikn theory).
Thanks for confirming my suspicion that it's clearly a Comcast issue (no surpise) :) :smileywink:
I swap out modem/srouters frequently to try new things.
I've not once called them to do so.
I've set it up using the app and using the browser for setup.
Everytime it was under 10 minutes to setup.
Again, this is on the consumer side.
you might want to read my post before u buy CAX80
Not everyone has problems with the CAX80.
- Seadog1975AspirantIm sure, but this is actually a Comcast business related issue. While their website says its supported, I'm finding that Comcast Business does not. It has something to do with Wifi/Router combinations which is why they only list DOCSIS midems as substitutes for their equipment.
- Seadog1975AspirantThanks. Already purchased. Read your post. Sadly, Ive had similar support experience with many companies. Unfortunate what passes for customer support these days.
