SuBiE
Feb 26, 2024Aspirant
CAX80
Anyone else have an issue with the reset button not resetting the router? I have tried the 30-30-30 method, and it doesn't work. Is there a way to achieve a reflash of the firmware by PC through other methods? Thanks!
The 30-30-30 reset should recover to the setup wizard that would be seen at 192.168.1.1. If this fails, then best option would be to contact NG support and see what the RMA options are for you.
- KitsapMaster
SuBiE wrote:Anyone else have an issue with the reset button not resetting the router? I have tried the 30-30-30 method, and it doesn't work. Is there a way to achieve a reflash of the firmware by PC through other methods? Thanks!
Your CAX80 has separate firmware for the modem section and for the router section. The Modem firmware can be refreshed only through your ISP. The router side firmware can be updated by the end user.
Go to the downloads section at the top of this page, enter your model number CAX80 and it will take you to a page where you can download the most recent firmware as well as the user manual.
Experienced users prefer to manually update the firmware via a computer connected to the router. For details on this process, here is a link: https://kb.netgear.com/000061836/How-do-I-update-the-firmware-on-my-CAX-series-cable-modem-router-or-CBR-series-cable-Orbi-router
Strongly recommend you avoid the Nighthawk mobile application for this task.
If you need to do a firmware default reset on the device, sometimes it takes a couple of passes to get it to take. i.e. reset using the recessed button on the back more than one time. You will have to reconfigure the router section from scratch. Again, avoid the mobile application.
Kitsap wrote:If you need to do a firmware default reset on the device, sometimes it takes a couple of passes to get it to take. i.e. reset using the recessed button on the back more than one time.
Adding to this, if you can use a web browser and the graphical user interface (GUI) to get into the controls, there is also an on-board "reset" option that does not need the "button" press.
- Advanced
- Administration
- Backup Settings
- Erase
While you are in there, why not create a backup, just in case you want to revert to the old settings?
- SuBiEAspirant
I have tried to reset multiple times. I am unable to access the webpage for some reason. I had access control on and when I went to reset the router (Wanted to start over with what I had configured and whatnot) It seems like it kept the settings but I am not able to access the page on the browser. I was hoping for a method to reflash the router by PC with tftp to hopefully fix this issue. Thanks!
If a 30-30-30 reset doesn't get you back into the modems web page at 192.168.1.1 then you'll need to make contact with NG support. There is no TFTP method that is supported on gateway modems that I know of.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Then clicking on "Get answers about NETGEAR products before I buy" then clicking on "Networking for Home" then "Chat with us".
