szcott's avatar
szcott
Century Link
does this ac1750 work with CL Fiber internet
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You would have to check with your ISP for supported modems.
    DarrenM
    • antinode's avatar
      antinode
      Guru
         "CL Fiber internet" could mean more than one thing, including a
      simple-looking Ethernet port, in which case, there would be no modem.
      Or, it could mean some kind of DSL link to the premises.
         If all you need is a router, then an R6300v2 should work.  If you
      need a modem, then you'd need a modem.  Ask CenturyLink what you need,
      or what they'd like to sell/rent you.
