OlaWetterling's avatar
Mar 27, 2017
CG2000-1TDNDS How do I set up?
How do I set up and get connected? Is there a manual to download?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Olawetterling
    Are you talking about the CG3000? did you but this modem or get it from your ISP?
    DarrenM
    • OlaWetterling's avatar
      OlaWetterling
      Thanks for your reply, Darren!
      I've got it from my internet provider (yousee, Denmark). For use with thei cable network in the building. Used coax connection. Is that's why? And would it work if I reste the router to "factory mode"? And then - how do I set it up?....
      • DarrenM's avatar
        DarrenM
        Hello OlaWetterling
        Yea you could try to factory reset the unit by holding the the reset button for 10 seconds. But you may need to contact your ISP.
        DarrenM
