Polly1308's avatar
Polly1308
CG3000 won't let me access Wireless settings
Using an Optus supplied Netgear CG3000 modem and I am wanting to change my wifi password.
When I go into the Wireless settings, I only see top half of options;
Wireless connection (blank) Manual (passphrase) Wifi Protected Setup (WPS)
Name (SSID)
802.11 Mode
Bandwidth
Sideband for control
Control Channel
APPLY button
I don't have secuirty options as showing in the guide ( https://kb.netgear.com/24368/How-to-change-my-wireless-name-and-password-Optus-CG3000)
I want to change the actual wifi password - I need to stop a housemate connecting to my modem so want to change the code.
Please help?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Polly1308
    Have you tried to use another web browser?
    DarrenM
  • Hi Darren
    Thanks yes, I tried Safari, Firefox, chrome and IE no success. In the end i called Optus ( my ISP) and after several calls, and supervisors involvement, I just reset the modem to factory settings and started afresh! It's now working perfectly.
    Thanks for your response :)
