jcgo16
Sep 18, 2015Follower
cg3000dv2 having wifi problem
hi im having a wifi problem with cg3000dv2
before it was ok, but when i tried to speedtest everything, it becomes 8-10Mbps max,
take note that my laptop, ipad, iphone, and android *lg g2* tested, same output
another note, i disconnect all wifi and lan connections before testing
any help?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Jcgo16
I would check your cable connections make sure your not using a splitter in between the wall and the cable outlet. also If you can try another cable outlet if you have another one active in the house see if you are still getting that slow of speeds. Last Id call your ISP tech support have them check the modem to see if they see issues with the level or if its a are utilization issue. They may need to send a tech out to your house to check the modem and see if there is any line issues. Hope to hear your feedback
DarrenM
