Fuzzzz's avatar
Fuzzzz
Follower
Aug 20, 2015
CG3000DV2 Wifi issues
Had this router for about a year or so and it looks like about a month ago I started having the same annoying issue - internet connectivity problems on mobile wifi devices. Everything wired always works, laptops connected via wifi seem to work while all the phones / tablets just lose it. Rebooting phones/tablets doesn't help, they successfully connect to the wireless network but internet doesn't work. Rebooting router always fixes the issue, but to be honest, this isn't a great solution if you ask me ...
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Fuzzz
    Have you tried changing the security type on the wireless  I have seen the past certain mobile devices only connect to certain security types on the wifi I would also try to remove the security altogether to just test to see if the issue happens without a wifi password. Hope to hear your feedback
    DarrenM
    • mjscott99's avatar
      mjscott99
      Tutor
      I have the same router, using firmware revision V1.00.05 (current version for my ISP, TWC).  I have the exact same symptoms.  Periodically (and it seems to be getting more frequent), wireless devices will lose internet connectivity, and frequently they cannot connect to the router at all.  During the same time, wired devices continue to access the internet just fine.  To be clear, ALL of the devices can properly connect to the router after it is rebooted.  It's running WPA2-PSK[AES].
      This happens with a WiFi range extender, an HTC One, iPhone 4S, 5C and 5S, an Acer laptop and a Viewsonic tablet.  Rebooting the router allows all of these devices to connect and work until the next time the router wireless function goes on vacation.
      Any potential fixes?
      • DarrenM's avatar
        DarrenM
        Hello mjscott
        Have you tried changing the wireless channel something could be causing interference with the wireless signal. If the issue keeps happening after trying different channels I would swap it back out with your isp if it was provided by them or contact netgear support to troubleshoot the issue to check that it might be hardware failure. hope to hear your feedback
        DarrenM
  • Same issue -- worked fine for a couple of months and then slow-no reach to where it previously worked. Infuriating, especially given the price of this modem-router. Comcast/Xfinity says it's not a cable issue on their end, no way to check if the firmware has been updated, and I cannot spend time powering down, unplugging everything, and powering up. Help! Should I just ditch this Netgear device and get another...switch to Linksys??
    • DarrenM's avatar
      DarrenM
      Have you guys tried to tell your mobile devices to forget the network and try again? you may also want to try and change the SSID and the security type on the wireless I have seen this fix strange issues with mobile devices on wifi.
      DarrenM
      • MeredithG's avatar
        MeredithG
        Tutor
        My issue isn't with a mobile device but with a laptop being used two floors down from the router. Was working fine until a few weeks ago.
