LanceHall01's avatar
LanceHall01
Follower
Sep 02, 2016
CG4500BD seemingly will not boot or fails boot startup
I just obtained a CG4500BD/N900 cable modem/WIFI Gateway. When I plug in the power, all the LEDs initially light but eventually the following LEDs are flashing as a group about once a second: WPS(green), 2.4GHz(green), 5Ghz(green), Power(red), Downstream(green), Upstream(green) & Internet(green). Doing the Reset button only repeats the same results as plugging in the power. I have to assume that this unit is clearly not happy at this point but is this unit somehow fixable? Help???
