Buju22
Sep 28, 2015Follower
Change DNS info for ?N450
How do you change the Primary and Secondary DNS for a Netgear n450? Once I log into the Netgear Gateway and click on Basic Settings, I can't click on anything to modify the DNS. Help!
- DarrenMSr. NETGEAR Moderator
Hello buju22
From what I can tell you cant make this change on this modem but I will double check on this.
DarrenM
- HancoAspirant
What is the answer please?
I'm really disappointed as it does seem to be impossible. Is there a "fix" and a way to do the change? Or is this for some odd reason limited to one setting??- DarrenMSr. NETGEAR Moderator
Hanco
This modem does not allow this setting to be changed. The Isp would push the DNS settings to the modem.
DarrenM
